Occasional Contributor I
SNMP for APs
Is there away to push out SNMP settings for APs managed by a 7205 controller?
I cant seem to find the place where to configure this :(
Best regards,
Re: SNMP for APs
What traps are you trying to see, the traps will be sent from the controller there is no traps from the AP. You can configure SNMP within:
Configuration > Management > SNMP
You can see which traps are disabled/enabled with the following CLI command:
#show snmp trap-list
...and enable/disable accordingly
(config) #snmp-server trap <enable/disable> <trap name>
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Re: SNMP for APs
I just wanted to be able to full information from the APs from our IMC, hostname, uptime, version, models etc
Re: SNMP for APs
there is no snmp agent on the APs, for what you want, query the wlsxWlanAPTable (aruba-wlan.my) on the controller, it has name, uptime, model, serial etc.
e.g. check the available fields using this or in the mib
snmpwalk -v2c -c public123 -O0X -mALL -M/home/mibs/6.5.4.3 192.168.1.123  wlsxWlanAPTable
or
snmptable -v2c -c public123 -O0X -mALL -M/home/mibs/6.5.4.3 192.168.1.123  wlsxWlanAPTable
