SNR
I have a client that gets an SNR of 12 and then 20 min later will get an SNR above 40?  He is science proff and his office is near some kind of lab.  He nor I are sure if anything in that lab is producing RF but it just seems odd.  There are 6 other clients associated to the same AP and they are averaging an SNR of 32.  Is there a tool that can pin point RF out put by device?
Contributor II
Re: SNR
I use the Spectrum XT analyze from fluke to find interferances in the RF spectrum.  Does all the user experience the drop in SNR at a particular time? or it is just a specific user?
Nils.
Re: SNR
If you have AOS6.x you can turn an AP105/135 into a spectrum analyzer device and measure the RF behavior
spectrum.html_warning=Continue_2013-10-30_14-41-24.pngspectrum.html_warning=Continue_2013-10-30_14-41-24.png
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Moderator
Re: SNR
From the client side, they can run inSSIDer (http://www.metageek.net/products/inssider/), this will show any other radios and spectrum that their clients can see.  Another thing they can try, get the 'Aruba Utilities' app for android phones to get another perspective of the environment from a mobile client.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
