Contributor II
SNR
majority of clients SNR shows 20 - 35 only, however the dashboard indicates no sign of a high interference, floor noise, interference and channel busy all shows in green, What could be wrong (why SNR not showing more that 45).
Retired Employee
Re: SNR
It also depends on the transmit power of the APs.
HT
Contributor II
Re: SNR
EIRP ?, if i increase, then intereference, noise floor increases.
Retired Employee
Re: SNR
I was just mentioning that EIRP is also one of the factors on the signal strength that the clients are receiving.
Do you have any specific concern based on the SNR received by the clients?
HT
Contributor II
Re: SNR
Thanks for reply, my concern is that why snr isonly 20 -35 when AP is nearby and no interference, floor noise is shown.
