Contributor I
SSH/WebUI Issues
We are deploying a new 7210 controller and very little configuration has been done on them, before we added licensing for AP/PEF we did a write mem and now can't access via SSH/WebUI. When trying to access web it now gives (securelogin.arubanetworks.com/auth/cp_disabled.html) Any ideas?
Re: SSH/WebUI Issues
Go into the controller using the console and make the interface that is connected to your lan "Trusted".  For example:
config t
interface gigabitethernet 0/0/0
trusted
Then try to get in using the web.
The problem is, when you add the PEF license, it makes all of the interfaces "untrusted", requiring web authentication, like a Captive Portal.  Making it trusted using the console might fix this.
Colin Joseph
Aruba Customer Engineering
Frequent Contributor I
Today, I faced this issue but yesterday I did not.
I tried to connect to another network and return to the network then it works without change.
I think sometime it is not stable.
VMC is running on the latest version (8.2.0.2-62929).
Thank you,
Ratchapas S.
You are commenting on a post 3 years old, that was not a VMC.  Your circumstances are probably different.
Colin Joseph
Sorry for that.
Thank you,
Ratchapas S.
