Occasional Contributor I
SSH connection problem with an HP switch in ArubaOS
I have a problem with HP switch under ArubaOS.
I try to connect by SSH on it, with Ansible (it is a platform that allows automate some tasks) for ping or to do some tasks, but it fails : | FAILED ! => {
   "changed": false,
   "failed": true
   "module_stderr": Connection to closed by remote hosts.
     "module_stdout": "SSH command execution is not supported",
     "msg": "MODULE FAILURE",
     "rc": 0
Knowing that I can connect me to the switch by SSH with the prompt.
Do I have to do any manipulations at the config level of the switch or do you think that it is a probleme with the platform that I use ?
