SSID Access Control
HI,
Do u have any ideas how to make these work:
1. students can only connect to student SSID ONLY
2. staff can only connect to staff SSID ONLY
for example:
- students wont be able to connect to staff SSID (fail to connect)
staffwont be able to connect to student SSID (fail to connect)
whats need to configure inside controller and Radius / LDAP
Re: SSID Access Control
Best practice would be to have a single SSID with roles being assigned by the RADIUS server.
What is your RADIUS server? ClearPass?
Tim Cappalli | Aruba Security
i cant do that because its in production. its not clearpass. normal radius. Can i do that ?
EDIT: the question was already asked by TCappy
Thank you
Victor Fabian
Lead Mobility Architect @WEI
This is users radius.. I think they use Windows server as the radius..
Shaiful Adli bin Yaakob
Acelync Networks Sdn Bhd
can u give me the link..
thanks..
Frequent Contributor II
I used to do something similar with Microsoft IAS using the filter ID RADIUS attribute and a server rule I set up.
Start with the RADIUS Attribute.
When a Student authenticates have IAS Send a filter ID of "Student" in the radius accept message.
Likewise send a filter ID of "Staff" for staff authentications.
You will need to create a unique server group for each SSID. The severs within the server group can be the same.
Under the Server rules section of the server group configuration create a rule to block access.  Something like.....
aaa server-group "Staff"
  set role condition "filter-Id" equals "Student" set value denyall position 1
aaa server-group "Student"
  set role condition "filter-Id" equals "Staff" set value denyall position 1
Hope this will help.
thanks..
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Working-DERIVATION-ROLE-for-DOMAIN-and-PERSONAL-workstation/m-p/132675/highlight/true#M9156
I understand what you saying..does the deny all will prevent the user from becomes connected with the user ID at all? I hope the user gets something like unable to connect.
