Contributor I
SSID Max IP Space
Alot of documentations say you shouldn't run larger than a /24 on a single SSID, we've been running a number of /22's for couple years now with no issues that we are aware of but are looking at moving to a single larger block. Anyone have any issues or newer documentation that talks about best practices or how large a block can be? Any experience with using larger blocks than a /22?
Re: SSID Max IP Space
A VRD addressing this was released last week.
http://community.arubanetworks.com/t5/Validated-Reference-Design/Single-VLAN-Architecture-for-WLAN/ta-p/257196
Tim Cappalli | Aruba Security
Trusted Contributor I
Great to finally see some documentation about this!
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
so true.
