Frequent Contributor II
SSID bridge mode configuration
I HV single 7210 controller AOS 6.4.4, AP 205 & 335 setup.
Controller is installed at HO. AP installed at branch location. Branch and HO. connected through MPLS link. Branch & HO HV different IP subnet. AP gateway IP is branch router IP. AP is able to ping controller IP.
I HV configured "Corp" SSID WITH DOT1X Auth, in bridge mode and assigned the the AP profile to respective branch AP. I want to avoid all branch traffic through controller except authentication.
Can someone plz suggest solution for below issue?
If controller goes down all AP reboots and I lost all existing wireless clients. It should not happen until and unless AP reboot or AP reauth expire.
Plz suggest how I can achieve the same.
Re: SSID bridge mode configuration
Explanations of options below.
The same requirement working for my other customer.
Is this new feature introduce in AOS?
There are two things that we could be talking about.
- Wan or Authentication Survivability requires that a controller is at the WAN site but stays up.  Access to authentication servers is interrupted but connectivity continues:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Branch%20Office/Branch_Deploy_features.htm
- Remote AP in Persistent Mode will allow an AP that already is up and bridges 802.1x users to stay connected to the same AP when the controller goes down:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Remote_AP/Advanced_Configuration_O1.htm?Highlight=remote ap
