SSID disappear
  • 1.  SSID disappear
    Posted Aug 01, 2013 10:15 PM
    We have a place,where put a AP93.Sometimes the SSIDs are all disappear.When it's happened,i try show ap active,bss-table,arm rf-sum,and ping it,look like all good.But,i can't see any ssids even change an AP.
    I try use an AP by the same config,It's always work.
    I have check controller log and airwave log,i think it don't have any error.
    Have anyone some suggestion?
    Thanks!
  • 2.  RE: SSID disappear
    Posted Aug 01, 2013 10:37 PM
    Do you mean this happens when you move the AP to another location ?
    Can you try the following command and see what BSSIDs are attached to that AP :
    show  ap  bss-table ap-name <apname>
    show  ap  debug system-status ap-name <apname> | begin iwconfig
    show datapath tunnel ipv4 <ap-ipaddress>
  • 3.  RE: SSID disappear
    Posted Aug 01, 2013 11:23 PM
    I have try bss-table,it look like fine.
    i will try the other two function when it happened.
    Thanks!
  • 4.  RE: SSID disappear
    Posted Aug 01, 2013 10:38 PM
    The AP 93 is a single radio AP and can only be on 1 band at any given time. When you run show ap bss-table, what phy type is your SSID using?
    Is your client 5 GHz (a/n/) capable? Could it be set to a single band in the wireless card properties?
  • 5.  RE: SSID disappear
    Posted Aug 01, 2013 11:28 PM
    My wireless card are capable both 2.4 and 5 GHZ.And AP93 is signle radio,it is working on 2.4GHZ.
    Thanks help!
  • 6.  RE: SSID disappear
    Posted Aug 02, 2013 06:32 AM
    After you confirm the other commands from my previous post you should check the following :
    Is there any flags when you do the show ap database | include <APNAME> ?
    Is the AP changing APgroups ?
    Are the LEDs for the g/a radio on the AP are lid
    Is the SSID configure to be hidden under the SSID profile ?
    And to make sure there's nothing misconfigured or missing do show profile-errors</APNAME>
  • 7.  RE: SSID disappear
    Posted Aug 04, 2013 09:32 PM
    The flag is "Rc2".
    AP no changing APgroups,and i put an ap at other place look like don't have issue.
    When i user AP93,the LEDs "PWR" "ENET""11B/G/N" are light.
    NO.
    I think no,this group have some VAPs other group is also have,but others don't have issue.
    It's not happened yet,so if it happened i will try your command.
    thanks for your help!
  • 8.  RE: SSID disappear
    Posted Aug 04, 2013 09:44 PM
    Did you meant to configured that AP as a Remote AP? , Rc2 means that is coming up a rap
  • 9.  RE: SSID disappear
    Posted Aug 04, 2013 09:46 PM
    Yes,it's a remote AP.
    Thank you.
  • 10.  RE: SSID disappear
    Posted Aug 04, 2013 09:52 PM
    When you get chance run this command :
    This will tell you which gre tunnels for SSIDs are making it to the AP
  • 11.  RE: SSID disappear
    Posted Aug 14, 2013 11:07 PM
    We put AP at another network line,and it's work fine almost two week.
    I think the issue is happened cause of a small hub.
    I will check more for this.
    Thanks for help.
  • 12.  RE: SSID disappear
    Posted Aug 18, 2013 09:32 PM
    We change a port connect to switch directly,and it work fine almost 3 week.
    So we think the issue is casue a small hub.
    We will check it.
    Thanks for help!
