SSID in tunneled Mode with different L2 and L3 configuration behind the MC
Hi Airheads Community,
I`ve a design question which I´m struggling with... please assume that I´m using a distributed enterprise MPLS environment with a Mobility Controller in a DC and ~30 Branch Offices where CAPs are used which are configured in Tunnel-Mode!
Mobility Controller / w CAP (tunneled mode) + AirWave only for Monitoring should be used!
the question for me is now, is it possible to broadcast an SSID on all those sites, but use for example several different VLANs and IP subnets each for every location behind the controller?
one reason is, that I would like to make a distinction of the clients based on the IP addresses... or is the only way to use several different SSIDs and VLANs on the MC to get this running done...
maybe some of you - hopefully not all :) would say to use Branch Controller in the offices and a Mobility Master in the DC as alternate solution or recommendation... if so, is there an overview comparison with advantages and disadvantges between MC /w CAP, MM /w BC and maybe IAP you can point me to?
thank you and kind greets
Re: SSID in tunneled Mode with different L2 and L3 configuration behind the MC
Is the majority if the user traffic going back to the DC?  If yes, tunnel all traffic back to the DC controller using a Campus AP.  If you are using Airwave, it will tell you what access point the user is connected to, so you will know the physical location.  No need to have separate, VLAN spaces for users.
That is my opinion based on the limited information in your post.
ok, I know that but would it technically be possible to use different vlans behind one ssid? ... you said limited information - what would be necessary else to know?
greets
Yes it would.
If you had a radius server and/or user derivation rules that would apply a different VLAN for each site, that would work, but it does not scale.
Regular Contributor I
Hi
Like Colin said you can use user derived rules. Or maybe create a AP group per location and use the different vlan in the different AP groups. The ssid can be one, based on the VAP within the AP group you assign a different vlan.
Hope it helps
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
as of you say a Radius Server or Clearpass for server derivation rules is unfortunately not available... so I´ve to if possible to deal with another solution! It is actually planned for a guest access so I´m not sure if that fits as well?!
there are already AP groups configured for each site but I don`t be able to configure it the way you are suggesting, because where in the AP Group I can specify a Vlan -  that has to be done in the WLAN (SSID) Tab or I´m wrong?!
greets
The VLAN is specified in the Virtual AP profile.  You would just duplicate that Virtual AP and change the VLAN for every ap-group
Like i already mentioned.
That should work fine
Cheers, Frank
hm, I can`t find a configuration parameter where I can specify a Virtual AP Group?! where should this be done in 8.2.1.0?
It is a challenge to tell you what to do without knowing what you have already done. Did you already create ap-groups?  Do you know at what folder level you created them?
