SSID not broadcasting
i have an aruba 650 and configured for my LAN users to autenticate via domain ,
i did "aaa test-server mschapv2 nps" and authentication was successful.
my problem is that my SSID is not broadcasted though i have done all configurations
on the controller and WLAN lan is seen on the GUI
i post output of sh ap database
AP_In_Procurement Office Test 105 192.168.1.127 Up 1m:48s 2 192.168.0.237 0.0.0.0
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
M = Mesh node; Y = Mesh Recovery
Total APs:1
it shows 2 in the flags column , some1 help.
Aruba
Re: SSID not broadcasting
can you include the full output of "show ap database long" to verify what AP Group the AP is in
Also, can you verify the following:
show ap bss-table
show ap-group <NameofAPGroup>  .....check if a virtual AP is present; if so, run:
show wlan virtual-ap <NameofVAP> .....check for SSID Profile name
show wlan ssid-profile <NameofSSIDProfile>  ......check for Hide SSID and Deny_Broadcast Probes fields
AMFX | ACCX | ACDX | ACMX
hers is the output
(Aruba650) #show ap database long
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP Wired MAC Address Serial # Port FQLN Outer IP User
AP_In_Procurement Office Test 105 192.168.1.127 Up 1m:19s 2 192.168.0.237 0.0.0.0 d8:c7:c8:ca:cc:b2 BE0223359 1/2 N/A N/A
Total APs:1
Aruba
What about the other commands above:
show ap bss-table ap-name "AP_In_Procurement Office"
show ap-group Test  .....check if a virtual AP is present; if so, run:
Contributor I
Do you have any vlan settings?  If not, this would keep the SSID from not broadcasting.  Also, check in your VAP profile that the "Virtual AP Enabled" checkbox is checked(GUI) or enabled.
Matt
Aruba
Also, check the following to see if there are any errors preventing it from coming up:  show profile-errors.
Please check this settings.
