SSID underlined gray
Hi folkrs ,
in my controller some ssid are underlined with gray ,  but all are active way ?
SSID Underlined
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: SSID underlined gray
Because there is a space in the SSID.
