SSL Certificate generation/installation issue
Hello community,
I am having a problem with getting an SSL certificate installed in my AMP 7.6.0.
I generated the CSR as mentioned in one of the replies in this thread:
http://community.arubanetworks.com/t5/AirWave-and-Network-Management/How-to-install-certificate/m-p/7076/highlight/true#M180
I was able to generate the CSR, get the certificate from the CA and install them just like described.
However, When I restarted the appachi nothing changed and the old SSL is still appearing on the HTTPS URL.
- How can I install the certificate correctly?
- What about installing the certificate usign the GUI? Should I merge the generted certificate with the private key before installing it?
- What if my certificate is published using an intermediate certificate? should I merge all the certificates in a p12 cert type file?
Thanks.
Amjad
Re: SSL Certificate generation/installation issue
I opened a ticket with the TAC and they provided the procedure. It is available in this link:
http://goo.gl/h5jOwc
The procedures I was following is not complete. it is missing some steps.
