Same mobile device to different SSID has different speed (Same AP)
  • 1.  Same mobile device to different SSID has different speed (Same AP)
    Posted Sep 19, 2017 02:40 AM
    I have problem with same windows mobile device connect to different SSID has different speed with same Aruba AP. Example: SSID A is authenticate through 802.1x with Microsoft NPS and SSID B is authenticate through WAP2.
    For SSID A, most of the device to connect to it was on "Client PHY a" with speed of 54Mbps. But when connect to SSID B "Client PHY is n 40Mhz" with the speed of 300MB, it was from same location.
    I did try to connect it to SSID A with the windows mobile device without join the domain the speed is 300 Mbps and "Client PHY is n 40MHz".
    Please advise. what is the problem as above?
  • 2.  RE: Same mobile device to different SSID has different speed (Same AP)
    MVP EXPERT
    Posted Sep 19, 2017 03:38 AM
    What are the data rates configured for each SSID? These can be set on a per SSID basis.
    #show wlan SSID profile XXXX
  • 3.  RE: Same mobile device to different SSID has different speed (Same AP)
    Posted Sep 19, 2017 03:47 AM
    For SSID A data rate is 270 mbps or above and SSID B is 54 Mbps or below.
  • 4.  RE: Same mobile device to different SSID has different speed (Same AP)
    Posted Sep 19, 2017 04:37 AM
    If you are using WEP or anything with TKIP, the fastest speed is 54.
  • 5.  RE: Same mobile device to different SSID has different speed (Same AP)
    Posted Feb 17, 2020 06:09 AM
    Changing encryption from wpa/wpa2 tkip to wpa2 aes resolved my issue.
