[Script] AutoSize (for smart devices/mobiles) Captiveportal - 1 click login [Script] #mhc
Hi AirHeads.
I edited/converted some script for my own usage - and i decided to share it with you. **ATTACHED AS ZIP FILE**
 (based on HTML/CSS/Java)
The script is enable u to build a auto-size captive portal page with 1 click login.
(Good for guest enviroments)
Tested on: Windows mobile/BB/Apple devices/Android devices/Windows Laptops/Linux Laptops
Before uploading it to your controller - edit the index.html as u want( change the ip to your controller ip)
edit the user agreement for your needs (change XXX  & Carlton Telaviv to your desire site/confrence name)
Be sure to enable guest login under your l3 aaa profile - captive portal profile
That's it - upload all the content + the index.html - and use it whenever u need it - your clients will be happy with minimalstic fast login page that auto-size/fit itself to any device.
Enjoy :)
