Super Contributor I
Search A Host Without Using FQDN
Recently upgraded AMP from 7.6 to 7.71 then 7.7.3 with CentOS upgraded to 6.  When I was at 7.6, I can search for a host with a partial name, but the current 7.7.3, a host must be searched with a FQDN.
For example: for a host name abc12345.domain.org, if I search for abc12345 it will not work, I must search for “abc12345.domain.org”
Any changes I can do to help this? It will help us a lot.
~Trinh Nguyen~
Boys Town
Moderator
Re: Search A Host Without Using FQDN
You'll want to check:
1. User preferred search method
Home -> User Info tab -> Search Preferences box
2. Global preferred search method
AMP Setup -> General tab -> Search Preferences box
Note that if you're using 'Exact Match' then it would require the full hostname.  Non-exact matches allow partial match.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Super Contributor I
Rob,
Thanks for the reply.  Here what I did:
In User info ->Search preferences -> search method: "Use system defaults" (no change)
Amp setup -> General -> Search Method: chaged from “Active + historical clients (exact match)”
 to “Active + historical clients”, (also tried with "Active + historical clients + all categories")
Then I logged out, logged back in, but no help, same problem: empty when searched for nerh123440, but it worked if search for "nerh123440.btnrh.boystown.org"
~Trinh Nguyen~
Boys Town
Super Contributor I
I should not say it is not working because when I put in the host name on the search box, if I clicked the search icon (the circle in the search box) it showed empty, but if I just simply hit ENTER, it works !!!
~Trinh Nguyen~
Boys Town
Moderator
That's definitely strange behavior.  Can you open a support case so they can gather more information?  I'm currently not seeing the same behavior on our demo server.
Rob Gin
Moderator
Actually, it's not strange behavior.
The 'magnifying glass' only performs the quick search functionality.  In order for quick search to be fast, it expects that the search term is at the beginning of the line.  So 'nerh' would not be expected to show any clients on quick search.  Though a search for 'host' would be expected to bring up the clients in quick search.
Keep in mind that when you hit enter, you're performing the search based on user preference.  Per user, the initial preference is by that particular user which is Home -> User Info -> search method.  If that setting is set to system default, then it's using AMP Setup -> General -> search method.
Rob Gin
