Separate Vlans for each wireless clients in AP group
I need to configure different vlans in floorwise wireless clients
Can anybody suggest me how to acheive this ?
I have attached the network setup
Re: Separate Vlans for each wireless clients in AP group
The big question is, how would you differentiate users on two separate floors, when users can easily roam to another floor?
Users look into this, and they end up putting all wireless users on the same VLAN, because there is not benefit to splitting them up.
Im Sorry for that i dont need for each wireless clients i need it for floorwise say 1st floor- all wlan clients in vlan -851,2nd floor-852...
and leases for all the wlan clients will get IP from DHCP server connected to edge switch as shown in diagram
How do you determine what user should be on what floor?
