Setting up ALE: hlep needed for PORT IAP
Hi, we set up ALE to connect to our Airwave server. During wizard we need to select SOURCE > and choose IAP .
Now it is asking for a PORT. Does anyone know which port to set?
MVP
Re: Setting up ALE: hlep needed for PORT IAP
You set the port in ALE and on the iAP
In ALE I have:
In iAP I have:
ale-server "10.0.8.15:8088"
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
