Contributor I
Setting up Syslog
I know the basics however I cant seem to get syslog to work correctly.
I'd like the controller to output to syslog web/ssh/telnet login information, physical changes i.e. port changes etc
I dont understand the severities. does it work by selecting for example the lowest severity for a category and that would mean it reports all severity above it?
For example I had them all enabled yet it never logged to syslog the fact I was logging into the GUI or failing to do so either.
I'm stuck!
Re: Setting up Syslog
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Audit-trail-to-syslog/m-p/24690/highlight/true#M6894
