Contributor I
Setting up WMM
Im looking to setup WMM nder the vap profile "GUEST" I see WMM traffic management, I created and enabled a profile called "GUEST WMM"
Then, under the SSID profile of "GUEST" I see a WMM checkbox, do i need to check that to enable WMM?
Re: Setting up WMM
If you have a SSID that supports 892.11n or 802.11ac, WMM is automatically enabled and is part of those protocols...
Contributor I
Re: Setting up WMM
Well that makes it easy. So I dont have to check any boxes or make any traffic managent profiles?
Is there anything else I need to know, like if I edit the EDCA values, do those take effect?
Re: Setting up WMM
You don't have to set anything up.  The question is, what are you trying to do?
Contributor I
Re: Setting up WMM
I was going through a VRD and it was talking about setting up WMM. Just trying to optimize.
Contributor II
Re: Setting up WMM
Are you trying to optimize or should I say prioritize traffic (voice/video)? Configure DSCP values?
