Contributor I
Show wired ap users
is there a option to view all RAP wired ap connected users / devices? I'm asking because the AAA profile and its inital role doesn't seem to be applied.
Re: Show wired ap users
If you assign a AAA profile to a wired port and make the initial role "authenticated".  You also need to make the port untrusted.  It will then show all wired users on a RAP port in the user table.
Colin Joseph
Aruba Customer Engineering
Contributor I
Making the Port untrusted did the job. Thanks!
