Signal fluxuation
Hi!  I have about 40 IAP105's deployed throughout my small K-8 campus..   half of the campus is old with brick walls, and the other half is newer with metal walls and such..   I pretty much have an AP in every classroom and a few halls ways..  they are really close to one another..  but there are several locations where clients are experiencing si\gnal fluxuations..   They aren't AP bouncing, they seem to be causing the AP to adjust power whenever the client reachers the wierd spots..     we have PowerDsine 9024g POEI powering the AP's..  its wierd.. I could stand right under an AP and just move into a bathroom 6 feet away with no obvious interference and the signal bars on the client just keep going strong/weak/strong/weak..  fluxuating every 10 seconds or so..
Anyone have any ideas?
Re: Signal fluxuation
On the IAP do you see a lot of power levels changes ?
What type of clients are you using?
What IAP OS you have installed?
Thank you
Victor Fabian
Lead Mobility Architect
Oh yes, lots and lots of power level changes....  Is that normal?
Of 150 clients, about 100 IOS... (ipads, iphones).. and 30-40 windows, and the rest android..
OS VERS:
Name:
Aruba Operating System Software
Type:
105
Build Time:
2013-02-15 22:20:03 PST
Version:
6.2.0.0-3.2.0.2_37229
A lot of power level  or channel changes is not good, run the following commands this should give you an idea of what's going on in your environment :
 Go to Support > and then run these commands :
AP ARM Neighbors
AP ARM history
AP ARM RF Summary
AP Monitor AP Table
Thank you
Victor Fabian
I can run those commands, but its all greek to me!   doesn't tell me anything..
But here it is:
5/20/2013 12:27:39 PM Target: COUN1 Command: show ap arm history
Interface :wifi0
ARM History
Time of Change Old Channel New Channel Old Power New Power Reason
2013-05-17 13:41:18 149+ 149+ 18 21 P+
2013-05-17 13:39:00 149+ 149+ 21 18 P-
2013-05-17 13:37:13 149+ 149+ Max 21 P-
Interface :wifi1
ARM History
2013-05-17 13:37:14 11 11 Max 21 P-
I: Interference, R: Radar detection, N: Noise exceeded, Q: Bad Channel Quality E: Error threshold exceeded, INV: Invalid Channel, G: Rogue AP Containment, M: Empty Channel, P+: Increase Power, P-: Decrease Power, 40INT: 40MHZ intol detected on 2.4G, NO40INT: 40MHz intol cleared on 2.4G, OFF: Turn off Radio, ON: Turn on Radio
5/20/2013 12:26:53 PM Target: COUN1 Command: show arm config
Minimum Transmit Power :15
Maximum Transmit Power :21
Band Steering Mode :prefer-5ghz
Client Aware :enable
Scanning :enable
Wide Channel Bands :5ghz
Air Time Fairness Mode :default-access
Custom Channels :No
2.4 GHz Channels
Channel Status
1 enable
2 disable
3 disable
4 disable
5 disable
6 enable
7 disable
8 disable
9 disable
10 disable
11 enable
1+ enable
2+ disable
3+ disable
4+ disable
5+ disable
6+ disable
7+ enable
5.0 GHz Channels
Channel Status
36 enable
40 enable
44 enable
48 enable
52 disable
56 disable
60 disable
64 disable
100 disable
104 disable
108 disable
112 disable
116 disable
132 disable
136 disable
140 disable
149 enable
153 enable
157 enable
161 enable
165 enable
36+ enable
44+ enable
52+ disable
60+ disable
100+ disable
108+ disable
132+ disable
149+ enable
157+ enable
5/20/2013 12:25:20 PM Target: COUN1 Command: show ap arm neighbors
ARM Neighbors
bssid essid channel rssi tx-power PL (dB) AP Flags Last Update (Total updates)
00:22:6b:68:69:c0 STMM 1 18 0 0 Passive
6c:f3:7f:3d:9b:02 SMM_GUEST 11 7 17 107 Passive
6c:f3:7f:3d:9b:03 SMM 11 8 17 106 Passive
6c:f3:7f:3d:8c:da SMM_GUEST 149 17 21 98 Passive
6c:f3:7f:3d:8c:db SMM 149 17 21 97 Passive
6c:f3:7f:3d:8c:d2 SMM_GUEST 6 14 7 88 Passive
00:90:4b:33:83:f8 6 40 0 0 Passive
6c:f3:7f:3d:9e:9a SMM_GUEST 157 9 21 105 Passive
6c:f3:7f:3d:9e:9b SMM 157 10 21 104 Passive
6c:f3:7f:3d:99:b3 SMM 1 44 17 68 Passive
6c:f3:7f:3d:9e:92 SMM_GUEST 1 21 17 90 Passive
6c:f3:7f:3d:9e:93 SMM 1 22 17 89 Passive
6c:f3:7f:3d:96:43 SMM 11 4 17 109 Passive
6c:f3:7f:3d:96:42 SMM_GUEST 11 5 17 107 Passive
6c:f3:7f:3d:9b:0b SMM 48 9 21 107 Passive
6c:f3:7f:3d:9b:0a SMM_GUEST 48 11 21 111 Passive
6c:f3:7f:3d:8c:d3 SMM 6 14 0 0 Passive
6c:f3:7f:3d:99:bb SMM 36 29 22 93 Passive
6c:f3:7f:3d:99:ba SMM_GUEST 36 29 22 94 Passive
6c:f3:7f:3d:9b:6a SMM_GUEST 44 39 21 77 Passive
6c:f3:7f:3d:9b:6b SMM 44 39 21 76 Passive
6c:f3:7f:3d:9a:d3 SMM 6 12 0 0 Passive
6c:f3:7f:3d:9a:db SMM 36 5 0 0 Passive
6c:f3:7f:3d:9a:da SMM_GUEST 36 5 21 112 Passive
6c:f3:7f:3d:99:b2 SMM_GUEST 1 43 17 66 Passive
6c:f3:7f:3d:9a:d2 SMM_GUEST 6 13 0 0 Passive
6c:f3:7f:3d:9b:63 SMM 1 46 17 66 Passive
6c:f3:7f:3d:8e:32 SMM_GUEST 11 4 17 108 Passive
6c:f3:7f:3d:9b:62 SMM_GUEST 1 45 17 67 Passive
6c:f3:7f:3d:96:4a SMM_GUEST 48 5 9 99 Passive
6c:f3:7f:3d:8e:33 11 2 0 0 Passive
Neighbor Summary:One hop 31 Two hop 0 Current Time: 2013-05-20 12:25:10
5/20/2013 12:24:03 PM Target: COUN1 Command: show arm-channels
2.4 GHz
Channel Status
1 enable
2 disable
3 disable
4 disable
5 disable
6 enable
7 disable
8 disable
9 disable
10 disable
11 enable
1+ enable
2+ disable
3+ disable
4+ disable
5+ disable
6+ disable
7+ enable
5.0 GHz
Channel Status
36 enable
40 enable
44 enable
48 enable
52 disable
56 disable
60 disable
64 disable
100 disable
104 disable
108 disable
112 disable
116 disable
132 disable
136 disable
140 disable
149 enable
153 enable
157 enable
161 enable
165 enable
36+ enable
44+ enable
52+ disable
60+ disable
100+ disable
108+ disable
132+ disable
149+ enable
157+ enable
Is that output from one of the IAP you are seeing issues from ?
Are you experiencing network drops on those wireless devices ?
Have you tried running a speed test to see if you are experiencing performance issues when the signal fluctuates  ?
Are you experiencing this on all devices : iOS and Windows devices?
Have you tried updating the drivers?
Those commands allow you to see the ARM RF information  on a particular AP:
show ap arm history
show ap arm history {ap-name <ap-name>}|{bssid <bssid>}|{ip-addr <ip-addr>}
Description
For each interface on an AP, show the history of channel and power changes due to Adaptive Radio
Management (ARM).
show ap arm neighbors {ap-name <ap-name>}|{bssid <bssid>}|{ip-addr <ip-addr>}
Description
Show the ARM settings for an AP’s neighbors.
show ap arm rf-summary
show ap arm rf-summary {ap-name <ap-name>}|{bssid <bssid>}|{ip-addr <ip-addr>}
Description
Show the state and statistics for all channels being monitored by an individual AP.
Thank you
Victor Fabian
Yes.. that is the output from just one of the IAP's that is in a spot that I am having problems..  I can put in another IAP in its place and will experience the same issue..
I am experience network drops and performance issues when this is happening..   Most of the time cannot get out to the web to perform a speed test...    ping times are really bad...
This is happening on all personal devices like iphones, ipads, android phones..  I can put a newer laptop in there it doesn't appear to be affected.
Also based on the output you provided it doesn't seem like there's a lot of power level / channel changes on that AP that you are having issues with.
Are you sharing the wireless IP segment with anything else on your environment ?
Thank you
Victor Fabian
So changing power levels 6 times in 2 minutes isn't alot?
2013-05-21 11:53:41 149+ 149+ 18 21 P+
2013-05-21 11:53:25 149+ 149+ 15 18 P+
2013-05-21 11:53:24 36+ 149+ 15 15 I
2013-05-21 11:50:55 36+ 36+ 18 15 P-
2013-05-21 11:50:54 36+ 36+ 21 18 P-
2013-05-21 11:50:48 36+ 36+ Max 21 P-
and I just tried a totally different POEI....
I don't know what you mean by sharing the segment..  all the AP's connect to my main switch..  which has everything else plugged into it..
On this particular output it does show a lot of power/channel changes in a small period of time , but the one you posted yesterday it didn't have that many power changes is this the same IAP ?
It looks like most of those changes are occuring on the 802.11a band , do you have those IAPs staggered ?
POEI ?
Do you have any other devices beside the AP/Clients on the using the same VLAN ?
Thank you
Victor Fabian
