Signal varying
Most of the device especially mobile shows signal continously varying .
Does indicate to a problem ?
Thank you
Re: Signal varying
Signals varying typically indicate reflections, collisions or higher utilization.  It also depends on the device and the application on the device that is measuring it.  The best way to determine if there is a varying signal is to do a packet capture and filter on a single access point to see if the signal is indeed varying.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
