Frequent Contributor II
Single Click Captive Portal?
For special events I now have a separate SSID / AP group that does not require authentication or encryption.
If I wanted to add a single click through CP like hospitals and hotels have where you have to at least glance at the disclaimer and then click the button before you can surf, how would I set that up? And also not screw up our standing CP login authentication for our other SSID.
Thanks ahead of time!!
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
Re: Single Click Captive Portal?
Start Here:
http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Captive_Portal.php
Then Go there here:
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-How-to-customize-the-Captive-Portal/td-p/15012
Here is a full HTML ready script for one time button (read all the post - and than download the needed files)
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Captive-Portal-Login-page-quot-Login-in-1-Click-quot-template/m-p/61172/highlight/true#M7230
*I also attached a great PDF'S regarding your question.
have a lovely day.
me
BTW:
Another good post that might give u an idea - from where and how to start:
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/HTTP-Script/td-p/13483
Awesomeness!! Thanks Kdisc!!!
Aruba
Review the HTML example in https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-154.   It has a "single click"  "Accept" button setup; shown below.
AMFX | ACCX | ACDX | ACMX
