Single IP subnet for clients of L2 cluster with NAT
Could someone, please, clarify me two questions regarding cluster of controllers running AOS8.
Cluster of 2 controller, L2 connected. Both controllers perfom a NAT/PAT function.
1. Can a clients be in the same IP subnet on both controllers or is it neccessary to divide it in two?
2. Is there a way to move failed controller's external IP to remaining controller or to share one external IP address on both controllers?
If there is a design guide that explain this in examples, please point it to me, because I haven't find any.
Re: Single IP subnet for clients of L2 cluster with NAT
- You shouldn’t have the clients subnet be on the same subnet as the controller to avoid issues from security and performance perspective .
- NAT is not supported for clustered controller in AOS 8
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you, Victor.
Probably I had to put a diagram to make myself clearer. It's better later than never. Diagram is in the attachment. Client's addresses are in different subnets.
If I'm going to use NAT function on a controllers I'll just use them without forming a cluster? Or is it not recommended?
Thank you in advance!
Alexander Suntsev.
NAT won’t work just because of how clustering behaves
If you really need the clustering feature then I suggest you have a separate controller or pair of controllers (not part of the cluster) handle your vpn connections
Thank you
Victor Fabian
