Occasional Contributor I
Site connection Failure - IPV6 issue
I have a problem when connecting to www.google.com mainly that the page does not connect.
All other sites that i try will connect fine, both http and HTTPS.
I notice that there is a IPv6 address for www.google.com on an NSLOOKUP
Non-authoritative answer:
Addresses:  2a00:1450:400c:c06::93
          74.125.132.147
          74.125.132.104
          74.125.132.105
          74.125.132.103
          74.125.132.106
          74.125.132.99
Is there a way to disable the IPv6 lookup??
Re: Site connection Failure - IPV6 issue
Can you turn it off on the client?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
IP V6 is not enabled on the client, as in the box is unchecked.
I'm apologize.
What client is this?
Windows 7, i have since found out www.wikipedia.org also has a ipv6 lookup via nslookup
This also doest not connect,but some time it does very strange.
