Frequent Contributor II
Site2Site that will work like Via Clients
We have via clients that successfully connect to our campus controller then are NAT'ed  out to our Core.
I have a remote Aruba650 controller that I want to set up in a similar fashion.  Right now I have a site2site connecting the 2 650 controllers, however the remote site can only access resources directly on the campus 650 itself, and will  not NAT out to the campus Core to access other vlans.  I have routes on the remote controller telling it to use the tunnel for ip ranges that exist on campus. And a route back to the remote controller on the campus side, however it seems the request stay only locally on the controller.   I spent about 6 hours total on the phone with TAC but no dice yet.   Here is a example of what I want to accomplish
MVP
Re: Site2Site that will work like Via Clients
Okay le tme see if i undertand you
You got 2 650 i see you got IPphone no the remote site
1-What it doesnt work is the Site to Site link?
2-you want to terminate VIA clients on the remote Site and those clients cannot go through the tunnel sucessfully
Which is your problem? 1 or 2? or both :)
Alternetworks Corp
