Slow throught put on wireless G
Client connecting with wireless A has perfect throughput but client connecting with wireless G is runnig dead slow. Aruba 650  with three aruba 105 AP.
Re: Slow throught put on wireless G
Interference? Contention on the 2.4ghz band? It is expected to be slower on g.
Colin Joseph
Aruba Customer Engineering
Frequent Contributor II
What kind of throughput are you getting when testing with tools like iPerf?
Do you see high channel utlisation on those radio's?
BTW: In your screenshot you are looking at a user that is in the "logon"-role. Is this user having issues? The logon-role would suggest this user isn't yet logged in.
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
