Contributor II
Sonos Boost in different subnet
we resently migrated a customer from a 3200 Master-Local setup with forward mode bridge enabled to a central standalone vMC running with forward mode tunnel
Unfortunately one of the connected remote offices uses a Sonos system. Since AOS8 does't support forward mode bridge, the clients are now in a central subnet and cannot connect to the Sonos system anymore. I already have ARP Broadcast to Unicast disabled and Airgroup is disabled
The remote office is connected over E-VPN. I guess we have to look into setting up L3 broadcast routing but I was wandering if there are other options . I have no experience with or access to Sonos equipment but know that disabling Broadcast enhancements on Instant usually does the trick.
Any help is appreciated.
Rgds, Erik
