Spectrum Load balancing predetermined thresholds
 Hi expert:
Where could I configure predetermined threshold of spectrum load balance?Search user guid but
Thanks!
Re: Spectrum Load balancing predetermined thresholds
Some info for you:
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-Spectrum-Load-Balancing/td-p/4698
more here:
http://www.slideshare.net/AirheadsSocial/managing-and-optimizing-rf-spectrum-for-aruba-wlans
i hope it will help u.
Colin Wang wrote:
 Hi expert:
Thanks!
Colin Wang,
Please be advised that on ArubaOS 6.3 and above, ClientMatch replaces spectrum load balancing.  If you have Clientmatch enabled, the spectrum load balancing algorithm is not active.
SLB and clientmatch together
Thanks for reply ,I still wonder for one thing.
Since "Legacy 802.11a/b/g devices do not support the client match feature" ,is it possible that we only enable SLB for 802.11 a/b/g ,then we enable client match for rest of device. or we just disable clientmatch as device use 802.11n or ac always don't have performence issue.
Re: SLB and clientmatch together
Colin Wang,
Legacy 802.11a/b/g ACCESS POINTS do not support clientmatch.  If you have 802.11n or 802.11ac access points, they will support Clientmatch, and you should be fine, even with 802.11a/b/g clients.
