Regular Contributor I
Spectrum analysis commands
Some of the spectrum analysis commands run on a remote AP save the file with the output -
Printing 60 lines to file(s) in /tmp/spectrum directory on the AP
How can I access these files?
I'm running this command on a controller running 6.1.3.5 code.
Re: Spectrum analysis commands
If you configure a tftp dump server this information will transfer to that server after your run the command.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-retrieve-a-core-dump-from-an-AP-in-the-event-of-a/ta-p/180550
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I have configured the dump server but no files arrive at the server when I run the commands. I know the server is reachable because it responds to pings and I can transfer a file from the controller manually using the copy command.
Sorry, it seems that only some of the commands have produced an output as I've run a couple more, one of which has resulted in a file being transferred successfully.
