Frequent Contributor II
Spectrum monitor mode
What is the difference between using the mode drop down box in the radio profile set to "Spectrum-mode" and the spectrum monitoring check box?   I moved an ap-225 into a profile where I had mode set to mode set to "spectrum-mode". now the AP is down I will have to wipe its configuration after I did that I rememberd not all models work with spectrum.
Is there a list of access points which work in spectrum mode?
Re: Spectrum monitor mode
Setting the radio to spectrum will not allow the AP to serve any clients.  It will allow you to do spectrum on all channels that the AP supports.
 Enabling the Spectrum checkbox will allow the AP to serve clients, but only do Spectrum on the channel it is currently on (hybrid spectrum)...
