Occasional Contributor I
Spectrum monitor
Hi there,
I would like to turn the spectrum analyzer on the 650 controller, but once created the new ap-group (spectrum mon.) and added 1 ap 5 of these, when I apply the change, all become ap spectrum monitor : why?
Thanx in advance.
Re: Spectrum monitor
create a new profiles...not just new ap-group.
if your two ap-groups using the same profiles it will effect all your ap's
Another method you can use if you just want to move one AP at a time into Spectrum mode is to use "Spectrum Override"
Go into Configuration-> Advanced Services->All Profiles->Spectrum Override.  Enter the name of the AP you wish to turn into a dedicated Spectrum Analyzer, select the band, and click apply.  To put the AP back into service go back to the same screen and delete the AP.
You must have changed the profile that the other AP group uses like mentioned above.
How to make a Aruba Spectrum Monitor
Sean Rynearson
