Split Tunnel Mode VLAN on Captive Portal
I had configured Remote AP, and used the Split Tunnel mode on the Captive-Portal SSID, It works with VLAN that attached with the Controller, and I have some questions. Can I use the VLAN on the remote site?
Re: Split Tunnel Mode VLAN on Captive Portal
What do you a vlan on the remote site?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Get Outlook for iOS
Thank you
Victor Fabian
I place the RAP on the Branch
Controller ---- WAN Link ---- RAP (Remote Site, Branch)
Controller's VLAN : 10,20,30
Branch's VLAN : 40
SSID : Captive-Portal-SSID (VLAN10)
and is it possible to change the VLAN Captive-Portal-SSID to VLAN40?
Not possible to do that.
Get Outlook for iOS
Thank you
Victor Fabian
Is it works only with the VLAN on controller?
Correct
Get Outlook for iOS
Thank you
Victor Fabian
Correct
Get Outlook for iOS
Thank you
Victor Fabian
