Occasional Contributor I
Split Tunneling failure
Hey folks,
We have some jobsites setup with the rap5wn. . They are experiencing some weird symptoms, access to our internal network here at headquarters is fine but when they go to the internet they cannot get out. They keep getting page cannot be displayed. We usually have to reboot the AP once (always first thing in the morning) and everything is then back to normal. Has anyone seen this before or does any know if there is some sort of timeout after inactivity that we need to set?  Thanks in advance and sorry if the explanation was long.
Re: Split Tunneling failure
What version of ArubaOS?
What is your ACL for authenticated users (show rights <role>)
Is your RAP in front of a cable modem DSL....?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
