Regular Contributor I
Split-tunnel bridge to tagged vlan
Hello community,
we've set up a split-tunnel deployment, so far everything works.
The RAP creates the tunnel to the captive portal, after authentication the traffic is bridged to the local LAN (in the untagged vlan of the RAP).
But we want the traffic to be tagged in a tagged vlan that is attached to the RAPs.
Is that possible?
What do I have to do to make this work?
Thank you very much
Super Contributor II
Re: Split-tunnel bridge to tagged vlan
Hi!
When using split tunnel the traffic you choose to "split" will be routed and source-nat:ed locally with the APs IP address. Since you always have your IP-address from a VLAN on the other side of the tunnel you must be NAT:ed to reach networks locally.
You can perhaps change where your APs on that site get their IPs, this is where the split traffic will go also.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
