Sporadically slow speed IAP-305 RW
We have five 305 APs in one of our offices and they are controlled and configured within Aruba Central.
Theese 5 AP are connected to a 2530 8G PoE+ Switch
We havent had the APs for that long and we have some issues that occurs sometimes!
The downspeed(measured on a webpage) is as slow as 0.2 mbit/s and the upspeed is around 10 Mbits. Did a login to aruba central and updated the firmware to version: and after the update it was back to normal speeds. But this morning the problem was back and after approximately 50 minutes it was back to working normal again.
I cant find anything within the logs I can generate in aruba central.
Do you have any ideas what could cause this?
Im new to Aruba systems and aruba central - So I just might have been missed to mark somethings :)
Thank you in advance!
