Occasional Contributor I
Static NAT on Controller 6000
We have a SSID "Contractors" for contract workers. The subnet is 192.168.1.0/24. They need to access a server on our network  which actual IP is 10.10.10.35. We don't want contractors to know the actual IP of server. We want contractors connect to 192.168.1.10, then the controller will redirect all traffic to 10.10.10.35. It is like static NAT on cisco ASA. Is there a way to accomplish this on Aruba Controller 6000?
Michael
Re: Static NAT on Controller 6000
We can accomplish this by using dst-nat, but it depends on the application.  What type of application is it?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Any traffic to certain IP will be redirected to 10.10.10.35.
The controller was working as bridge, and the dst-nat was as below. It didn't work.
ip access-list session "NAT Internal Server"
  any host 192.168.1.10 any  dst-nat ip 10.10.10.35
I changed the controller to work as router - gateway is on controller. changed host ip to 2.2.2.2. it worked.
  any host 2.2.2.2 any  dst-nat ip 10.10.10.35
Question:
1. Does controller need to router in order to use dst-nat?
2. Is the host IP must be on different subnet?
