Frequent Contributor II
Sticky Clients
I have a 3200 controller running 6.1.3.8 and it looks like devices are hanging on for long periods of time based on the number of clients connect to it.  If I reboot the controller  will it release all of the clients?
Re: Sticky Clients
Do you mean the devices are sticking to an AP and not roaming or devices
aren't aging out of the user table when they deassociate from the network?
Tim Cappalli | Aruba Security
Re: Sticky Clients
Re: Sticky Clients
You can clear the user table without reloading the controller by issue the
command "aaa user delete all"
Re: Sticky Clients
Thank you.  That did the trick "for now".  This install is in a hotel and I am also wondering it I am running out of IP address.  Currently the controller is running DHCP.
Re: Sticky Clients
Also check your user idle timeout. It defaults to 5 minutes.
Configuration > Security > Authentication > Advanced
Re: Sticky Clients
Currently it is set to:
Re: Sticky Clients
That's a long time. That means it could be up to 4 hours after your client leaves the network that they are cleared out of the user table. You may want to try and lower it to 1800 seconds (30 mins).
