Strange problem with Aruba IAP 105s..
I am having a strange issue with our recently installed Aruba instant network.  It seems like our DNS is not always being passed through from our DHCP server to clients on the wireless network.  Clients are able to connect to the APs, and they can usually get to the gateway, but authentication to any of our servers is a crapshoot; some work, some don't, and there doesn't appear to be a rhyme or reason as to why.  We've recently had some other problems on our network, so I'm not ruling out a setting amiss on our DNS or DHCP servers, but I'd like some other ideas as well.  Optimal settings would be helpful; we're running a flat network topology, so it shouldn't be an issue with routing.  We've tried running open encryption on our network to make sure that wasn't the issue; it's made no difference.  Any ideas?
Re: Strange problem with Aruba IAP 105s..
What do you mean when you say its crapshoot;?
When you say it does not get the DNS when you do a ipconfig /all you cannot see the DNS? or you can see it but its not working?
I would check the DNS i would try using maybe a public one just for testing...
The captive portal willl not work if the computer cannot resolve names... so check that.  The easiest way to test it, it justby changing it or doing ping to pages you have not even opened  which you know they arent in the cache of the machine... but well i would do this
Connect
Ping the gateway
ping something in internet like 4.2.2.1 or 8.8.8.8
If that work well you got internet
After that iwould ping someting likeping www.cnn.com
or some other webpage... if it cannot resolve the name to a ip addresss then thats the problem.
Try pinging many different names.
Cheers
Carlos
Alternetworks Corp
I would check to make sure that you don't have two DHCP servers in your network.
So, it turns out that rebooting the AP I was working with solved the issue.  I'm still not sure what caused the problem, but it appears to be working now.  Thanks for the replies folks. :)
Good to hear its working :)
Alternetworks Corp
