Student Intern Wireless Help
We have just been assigned for our intern class to configure a 3200 Aruba Controller for the end product to give a wireless access point to a guest (similar to what the campus has), We were tossed in a class room with not much help. Me and my friend have connected to it through xshell4 and set up. What would the next steps be? they also gave us a cisco catalyst switch 3750. Thanks alot guys
Re: Student Intern Wireless Help
Here's a few links to the user guides which should help you get started. I'm not sure we should help you directly with your homework. :smileyhappy:
ArubaOS 6.2 User Guide
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=9143
ArubaOS 6.2 Quick Start Guide
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=10382
ArubaOS 6.1
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=5926
Tim Cappalli | Aruba Security
They told us to come to this website if we needed help with steps or anything else. Thanks for your respose. Im still lost of what to do next but i will figure it out.
When you connect via console, are you being presented with the quick setup wizard?
No i do not. No wizard at all only thing i can connect so far to the aruba 3200 is through the shell. The network admin wiped the whole thing so we can start from scratch. So far i have only through the Shell set up the admin and password(basic stuff) i am not good with networking. (I think im supposed to configure ip address or set up my pc to connect with the 3200. Not sure though probably entirely wrong.)
http://www.arubanetworks.com/controller_setup_video.html
Trusted Contributor I
lol, easy way to run your classes, give the students some gear and point them to the vendor forum for help :)
