Frequent Contributor II
Stupid ground wire question
Sorry to be dense, but the AP 270 installation says what to do with one end of the ground wire (connect it to the ground point), but not the other end. Can I attach the "ground" side of the wire to the mounting arm? Or the wall or pole to which the mount is attached? How? Just wrap it around a screw?
Kind of irritated that a ground wire was not included in this expensive AP. Hoping to buy the prebuilt, 6" jobs is those will work.
Thanks!
Community Manager
Re: Stupid ground wire question
Yes, any area you feel is properly grounded I believe will work. Thats what I do.
Airheads Community - The best place to Connect. Engage. and Learn.
A ground wire is not included because different localities and regulations dictate what ground wire (size, type, etc) is required by local CE/code. Also, some ground wires need to be exceptionally long and to include the wire with the AP would greatly increase the cost of production, shipping costs, etc which get passed on to the buyer. Finally, it's not common industry practice to include ground wires from any vendor.
Regarding where to ground on the AP, if you look at the installation guide, there is a specific lug right between the two ethernet connection ports for the ground. The other end should be installed or attached to the building's 'common ground', grounding from the AP to the moutning arm is not likely sufficient unless the arm is mounted to a metal building and local codes qualify the entire building skin as common ground. If it's mounted to brick or stucco, etc, then it would not be grounded.
Hope that helps.
Jerrod Howard
