Survey signal strength Vs Client Rssi
Passive survey shows the least signal in the area is  -65 dBm.
But the 5 ghz client still connect to  2.4 Radio . Client getting -82 dBm from the AP's (Apple airport utilities)
2)
I disabled the radio of 2.4 Ghz , Then the apple phone connected to -68 dBm
Why ?
