Hi:
I've swapped out my old 3400 Master controller with a 7210 controller. Both are running the same OS version.
Aruba TAC told me to just make a flashbackup of the old controller and restore it on the new one, and then I would only have to configure interfaces.
But the results have been a disaster.
Much of the config did not transfer.
I'm going through the old and new config line by line and pasting in what didn't make it. (unfortunately, the new config is ordered just differently enough to fool file compare programs.)
After I paste in anything that didn't make it, does anyone else know if there's anything else I will have to do?
One particular problem, is that my guest network (controlled by CPPM guest) is now redirecting to:
https://securelogin.arubanetworks.com/auth/cp_disabled.html and I'm getting a message:
Web authentication is disabled. Please contact the administrator for assistance."
Does anyone have a clue what issue that might be?
Tony
#7210#3400
