Trusted Contributor I
Sync RAP whitelist between standalones
Is there anyway to sync a RAP whitelist between standalone controllers?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Aruba
Re: Sync RAP whitelist between standalones
No automated way, no.  You can either manually export/import or use an external source like ClearPass or Activate.
AMFX | ACCX | ACDX | ACMX
