Contributor I
Syslog
[ Edited ]
I am tracking User Authentication Syslog Messages (522008).  I enable logging of these messages using "logging level notifications user process authmgr".
When I establish a new wireless connection, the Auth syslog message is generated.
When I connect to another SSID and return to this SSID, the Auth syslog message is generated.
When I disconnect and then reconnect to the same SSID, I do not get the Auth syslog message.  I need the syslog message for this scenario as well. Is there something I can do to generate it?
Thanks.
