System is halt and can't boot OS
How to fixing this probelm?
I have a probelm when installing aruba controller 7210. Power status is off and can't boot OS, command appears on the controller when i use console are :
Stage 1 Loader 1.0.2.0 (build 43722)
Built: 2014-05-13 at 10:07:14
Secure Boot Enabled on the Processor
Initialized I2C0 Controller.
Initialized I2C1 Controller.
SPD Rev:0x12 DIMM:0 Type:2 Speed:800MHz #Rank:1
DDR3: Node 0 Channel 0 Mem size = 2048 MB UDIMM
DDR3: Node 0 Channel 1 Mem size = 2048 MB UDIMM
DDR3: Node 0 Channel 2 Mem size = 2048 MB UDIMM
DDR3: Node 0 Channel 3 Mem size = 2048 MB UDIMM
Ref Clk @133MHz
DDR3: Node 0 DRAM frequency 800 MHz
DDR3: Node 0 CPU frequency 800 MHz
mtb_ps:125 clock:1250 trc:39 trcd:11 trp:11
AP3:A0CFFF0 ODTP1:10000
Board DDR VDD set to 1.5V.
N:0 CH:0 additional rdlvl rdly:1
N:0 Ch:0 m:32 s:32 R OK.
Rank:0 HW WLVL Passed Mask:1FF
n:0 ch:0 RTT WR:0200
===N:0 Ch:0 m:32 s:32 RW OK.
Starting address/cmd align [4T..3T]
N:0 CH:0 SR ADDR/CMD:(B:00 E:5D 00) 2E
N:0 CH:0 MR ADDR/CMD:(00 7F 00) 3F
n:0 ch:0 addr mode:4T OK
n:0 ch:0 addr mode:3T OK
Node:0 Ch:0 TGE Set Memory:2048 MB value:FF FF -- PASS
Node:0 Ch:0 TGE Set Memory:2048 MB value:FF 00 -- PASS
Node:0 Ch:0 TGE Set Memory:2048 MB value:AA 55 -- PASS
Node:0 Ch:0 TGE Set Memory:2048 MB value:00 00 -- PASS
N:0 CH:1 additional rdlvl rdly:1
N:0 Ch:1 m:32 s:32 R OK.
n:0 ch:1 RTT WR:0200
===N:0 Ch:1 m:32 s:32 RW OK.
N:0 CH:1 SR ADDR/CMD:(B:00 E:5E 00) 2F
N:0 CH:1 MR ADDR/CMD:(00 7F 00) 3F
n:0 ch:1 addr mode:4T OK
n:0 ch:1 addr mode:3T OK
Node:0 Ch:1 TGE Set Memory:2048 MB value:FF FF -- FAIL
Node:0 Ch:1 TGE Set Memory:2048 MB value:FF 00 -- FAIL
Node:0 Ch:1 TGE Set Memory:2048 MB value:AA 55 -- FAIL
Node:0 Ch:1 TGE Set Memory:2048 MB value:00 00 -- FAIL
XLOAD ERROR:-1
Exception Error :
EPC(CP0 No.14) : 0x00000000 (Failed Address)
Status(CP0 No.12) : 0x740000c4
Cause(CP0 No.13) : 0x40008078
TI(Internal Timer Interrupt)
IP7-0(Interrupt Pending) : 0x80
7 6 5 4 3 2 1 0
1 0 0 0 0 0 0 0
ExcCode(Exception Code) : 30
EPC(14) : 0x9fc0e220
BadVAddr(8) : 0x00000000
EBase(15.1) : 0x80000000
IntCtl(12.1) : 0xf8000000
EIRR(9.6) : 0x0000000000000080
CasheErr(27) : 0x00000000
ECC(26) : 0x00000000
ErrorEPC(30) : 0x9fc00750
HALT HERE
Re: System is halt and can't boot OS
open a TAC case it will the quickest way to resolution
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
let us know the outcome
ACDX #420 | ACCA
Hi all,
i just meet this error and i would like to ask got any solution about this error.I just upgrade firmware then reboot the contoller then system is halt....please help..thx
That is typically a hardware issue that should be addressed by TAC.
Hi,I just upgrade controller firmware Aruba os 6.4.4.3 to 6.4.4.9 only also
can make hardware faulty? Or got any reason to make hardware faulty?
Not that I know of, but TAC should be able to resolve it.  We would only be able to guess what has happened here...
