Technical Climb Webinar
Hi All,
This thread is for those who are attending RF training webinar conducted by TAC for Customers and Partners of different regions.
Since the number of registered participants is high, we wont be able to answer your questions in the session. Unmuting will also cause voice quality problems.
So please post your questions in this thread and we will answer all your questions shortly.
You can find the presentations in the below link.
http://www.slideshare.net/dhanraj_puduchery/wireless-fundamentals-49411271
Venu Dhanraj
Aruba Networks
(ACMP, CWNA, CCNP )
Re: Technical Climb Webinar
My self and another colleague did not receive the invitation. It does say that it will be available on afp.arubanetworks.com, this address times out. Any help?
Edit: I believe this is the second time an invitation has not been sent after registering
Hi All, Has the link to the recording been issued as of yet? I have told a number of colleagues about the presentation and they are keen to watch it. Thanks Gordie
Valued Contributor II
HI Friend,
It should have shared already by this time. please contact Cristina on this.
Cheers,
Venu Puduchery,
HI,
Here is link to access the Video,
https://arubapedia.arubanetworks.com/arubapedia/index.php/Pinnacle:_Technical_Climb#Europe.2C_Middle_East.2C_Africa
Cheers,
Venu Puduchery,
Hi Venu,
I get a permission denied after logging using this link?
Hi friend,
It is accessible for Partners.
 please check with Cristina on this.
Cheers,
Venu Puduchery,
Regular Contributor I
I am a partner but it is denying access to me also.
How much resources does ClientMatch use on instant APs (lets say a moderately loaded Aruba 205AP) in a network? Does it reduce performance in some ways?
Rasmus
Q1: what will happen if clientmatch let one client from one RAP to another RAP in slpittunnel mode, means clientmatch can support RAP split-tunnel mode, or split-tunnel roaming?
in different forwarding mode, what we should consider the realationship between L2/L3 roaming and Clientmatch?
Q2: clientmatch will has GUI configuration IN THE FURTURE?
Q3:in AOS 6.4 CM won't support 802.11n AP, so if we disable CM ,means no LB and band-steering function. right?
