Frequent Contributor I
Technical Specifications of Aruba APs (IAP92, IAP105, AP105, AP124)
[ Edited ]
In case anyone else was wondering like me what the technical specs are of some of the APs are since they aren't posted anywhere on Aruba Support, CPU, RAM, Flash, etc, I consoled into all the Aruba APs I havein my lab to figure out their true technical specs hidden inside and put together a rough spreadsheet of what I have figured out.
I was led to believe by other posts on this site that the IAP-105s had different specs than the AP105 due to the nature of them having to run a virtual contorller, well... this is not true.  IAP105 and AP105 had the same exact specs.
Feel free to add to this so everyone can get an idea of what the specs are of other Aruba APs out there.
Re: Technical Specifications of Aruba APs (IAP92, IAP105, AP105, AP124)
Could one assume the AP-125 is the same as a 124?
Aruba
Yes, AP-125 and AP-124 share the same hardware platform.
/Onno
Anyone know the specs on the AP-135s?
So why is the CPU and Memory depth important to you?  What are you trying to gleen from that information?
The technical specifications are clearly spelled out on the Data Sheet for the individual AP's.
