Airheads Gadget Princess
Technical Webinar- Recording + Slides - What does AirMatch do differently?
What does AirMatch do differently_.pngHello Airheads,
Adding this post here to share the content of the Airheads Technical Webinar we delivered yesterday, November 28th onWhat does AirMatch do differently?. For those who could not attend the session please find below:
Webinar Recording:
https://attendee.gotowebinar.com/recording/168761127630181132
Webinar Slide Deck - below and attached
Please note that you can find additional on-demand technical webinars on our Airheads webinar repository page.
As well we have our final December webinar available here
Please feel free to leave any additional comments and questions you may have below. We will make sure to answer them as soon as possible.<!--
Re: Technical Webinar- Recording + Slides - What does AirMatch do differently?
Our speaker Sajin was kind enough to also share the AirMatch troubleshooting commands listed in the webinar- access them below or share the attached document with your teams/ colleagues:
Troubleshooting commands:
Enable debugging:
(ArubaMM) *[mynode] #configure t
Enter Configuration commands, one per line. End with CNTL/Z
(ArubaMM) *[mynode] (config) #logging system level debugging
(ArubaMM) *[mynode] #show log system all  | include Air
Dec 14 03:12:26  AirMatch[6258]: <356381> <6258> <DBUG> |AirMatch|  Recvd PAPI message buflen 320 msglen 244
Dec 14 03:12:26  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  airmatch_cli_db_dump: Free space in flash : 4191 MB, required space = 3072 MB
Dec 14 03:15:15  AirMatch[6258]: <356381> <6258> <DBUG> |AirMatch|  Recvd PAPI message buflen 322 msglen 246
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  MCELL Solver starts ... (Runmode Quick) (switch_ips <>) (deploy_time 1513250116)  >>>>>>>>>>>>>> will show the mode, here its airmatch quick mode
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  DB: Taking snapshot ...
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  DB: Loading network site1 ...
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  DB: 374 unique interferes causing 374 interfering nbr_pathloss links
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  DB: Ratio intf/friend = 287/0 = 287.0. Ignoring intf nbrs
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  DB: Raw data: #AP 1  #Radio 2 #Feasibility 2 #Pathloss 0
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  SANITY: Raw data Sanity check ....
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  SANITY: ........ Raw data Sanity check (DONE)
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  Reconstructing the network: site1 5GHz ...
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  ANALYSIS: #RF domains: 1. Sizes 1
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  ANALYSIS: (all:friend:intf) #APs (1:1:0) #Radios (1:1:0) #Ignored intfs: 0
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  ANALYSIS: AP Models: AP-115(1:100.0%)
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  ... Reconstruction (Done)
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  BEFORE: oper network band 5GHz narc 2.0 conflicts 0.0
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  Reconstructing the network: site1 2GHz ...
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  BEFORE: oper network band 2GHz narc 4.0 conflicts 0.0
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  ... Loading DB to Topology (DONE)
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  SIZING:   band 5GHz: 1 RF domains  Algorithm 14
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  SIZING:   band 2GHz: 1 RF domains  Algorithm 14
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  PARTITION: ...
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  PARTITION: ... DONE
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  COLORING: band 5GHz: 1 RF domains (Runmode 2)
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  COLORING: ALGO CIR for site1-rfd1-hgh-part0  1 radios 5GHz CBW20
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  COLORING: ALGO CIR for site1-rfd1-hgh-part0  1 radios 5GHz CBW40
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  CBW20 band 5GHz (capacity:  1.0/conflicts:  0.0/narc:  4.0), CBW40 band 5GHz (capacity:  2.0/conflicts:  0.0/narc:  2.0),
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  COLORING: band 2GHz: 1 RF domains (Runmode 2)
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  COLORING: ALGO CIR for site1-rfd1-hgh-part0  1 radios 2GHz CBW20
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  CBW20 band 2GHz (capacity:  1.0/conflicts:  0.0/narc:  4.0),
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  AFTER: solution band 5GHz narc 2.0 conflicts 0.0
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  AFTER: solution band 2GHz narc 4.0 conflicts 0.0
Dec 14 03:15:24  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  ... MCELL Solver (Done)
Dec 14 03:15:34  AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch|  CLI CMD PASS: airmatch ap set ap-name AP-115 band 5GHz eirp 21
How to check the airmatch history for an AP?
(ArubaMM) *[mynode] (config) #show airmatch debug history ap-name AP-115
2GHz   radio mac 18:64:72:ab:e6:40  ap name AP-115
Time of Change       Chan              Bandwidth      EIRP(dBm)    Mode      Source
2017-12-14 02:52:13        6->     11     20->   20    120->  12   AP ->AP   Solver
2017-12-14 02:51:03        1->      6     20->   20    120->  12   AP ->AP   Solver
2017-12-13 05:01:15        1->      1     20->   20    120->  12   AP ->AP   Solver
2017-12-12 05:01:17        1->      1     20->   20    120->  12   AP ->AP   Solver
2017-12-11 13:01:13        1->      1     20->   20     80->  12   AP ->AP   Solver
2017-11-20 13:01:45        1->      1     20->   20      9->   8   AP ->AP   Solver
2017-11-19 13:01:46        1->      1     20->   20      8->   9   AP ->AP   Solver
2017-11-13 13:01:28        1->      1     20->   20      7->   8   AP ->AP   Solver
2017-11-11 13:01:28        1->      1     20->   20      8->   7   AP ->AP   Solver
2017-11-09 13:01:19       11->      1     20->   20     12->   8   AP ->AP   Solver
2017-11-09 05:01:16        6->     11     20->   20      9->  12   AP ->AP   Solver
2017-10-27 05:01:15        6->      6     20->   20     25->   9   AP ->AP   Solver
5GHz   radio mac 18:64:72:ab:e6:50  ap name AP-115
2017-12-14 02:51:13       44->     44     40->   40    210->  21   AP ->AP   Solver
2017-12-14 02:50:03       40->     44     40->   40    210->  21   AP ->AP   Solver
2017-12-13 05:00:15       40->     40     40->   40    210->  21   AP ->AP   Solver
2017-12-12 05:00:17       40->     40     40->   40    210->  21   AP ->AP   Solver
2017-12-11 13:00:13       40->     40     40->   40    150->  21   AP ->AP   Solver
2017-11-21 08:31:56       36->     40     40->   40     15->  15   AP ->AP   Solver
2017-11-13 13:00:28       36->     36     40->   40     16->  15   AP ->AP   Solver
2017-11-12 13:00:28       36->     36     40->   40     15->  16   AP ->AP   Solver
2017-11-10 13:00:19       36->     36     40->   40     16->  15   AP ->AP   Solver
2017-11-09 13:00:19       64->     36     40->   40     21->  16   AP ->AP   Solver
2017-11-09 05:00:16       64->     64     40->   40     18->  21   AP ->AP   Solver
2017-10-27 05:00:15       64->     64     40->   40     22->  18   AP ->AP   Solver
Checking neighbor information.
(ArubaMM) *[mynode] (config) #show airmatch debug nbr ap-name AP-115 | begin 5GHz
Nbr Mac            Is Friend  Path Loss(dB)  Channel      Last Update          AP Name
ac:a3:1e:00:a6:90      *           40               60    2017-12-14 02:53:13
84:d4:7e:bd:91:10      *           84               36    2017-12-14 02:53:13
84:d4:7e:d3:61:b0                  59              108    2017-12-14 02:53:13
ac:a3:1e:57:48:d0                  60              149    2017-12-12 06:17:56
34:fc:b9:2b:10:50                  61              161    2017-12-14 02:53:13
18:64:72:a0:73:b0                  63               36    2017-12-14 02:53:13
18:64:72:ab:e9:70                  63               56    2017-12-14 02:53:13
40:e3:d6:5e:51:f0                  63               36    2017-12-14 02:53:13
Check the last optimization:
(ArubaMM) *[mynode] #show airmatch debug optimization last
# 2017-12-14_03:15:16     Quick
# 5GHz   network cost/solution cost/improvement: 2/2/0%
# 2.4GHz network cost/solution cost/improvement: 4/4/0%
# Band Radio             RFDom Part  Chan  CBW    EIRP(dBm)  APName
                          ID    ID
  2GHz 18:64:72:ab:e6:40   001   000     6     20        12   AP-115
  5GHz 18:64:72:ab:e6:50   001   000    44     40        21   AP-115
[*] regarded frozen | [i] channel ignored because insufficient quality increase
How to check static radios:
(ArubaMM) *[mynode] #show airmatch debug static-radios
How to gather dump:
(ArubaMM) *[mynode] #airmatch db-dump all
db-dump complete. File name is 'airmatch_db_dump.tgz'
(ArubaMM) *[mynode] #dir
-rw-r--r--    1 root     root        74245 Dec 11 04:17 AUDITTRAIL-HISTORY.log
-rw-r--r--    1 root     root        19536 Dec 11 04:17 AUDITTRAIL-LOGIN_OUT-HISTORY.log
-rw-r--r--    1 root     root      2181979 Dec 14 03:12 airmatch_db_dump.tgz  >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
drwxr-sr-x    4 root     root         4096 Sep 15 06:15 archives
How to check the AP feasibility information:
(ArubaMM) *[mynode] #show airmatch debug feasibility ap-name AP-115
Field                    Value
Mac                      18:64:72:ab:e6:40
Last Update              2017-12-14 03:38:18
Chan 20MHz               1,6,11
Chan 40MHz
Chan 80MHz
Chan 160MHz
Bandwidth                20MHz
Config   BW   range(MHz) 20 - 20
Hardware BW   range(MHz) 20 - 40
EIRP(dBm)                6 - 12
Config   EIRP range(dBm) 6 - 12
Hardware EIRP range(dBm) 3 - 25
EIRP Offset(dB)          0
Update Reason            Periodic Update
Field                    Value
Mac                      18:64:72:ab:e6:50
Last Update              2017-12-14 03:38:17
Chan 20MHz               36,40,44,48,52,56,60,64,149,153,157,161,165
Chan 40MHz               36,44,52,60,149,157
Chan 80MHz
Chan 160MHz
Bandwidth                20MHz,40MHz
Config   BW   range(MHz) 20 - 80
EIRP(dBm)                15 - 21
Config   EIRP range(dBm) 15 - 21
Hardware EIRP range(dBm) 4 - 22
EIRP Offset(dB)          0
